I’ve been having issues with my high beam selector off and on the low beam works fine, but the high beam is intermittent when it will work or not. When it does not work, it kills the low beam as well so essentially when I’m trying to use my high beam. I lose all headlights completely. I replaced the being selector and that seemed to fix it, but I’m having the same problem again and so my question to the group is, does the beam selector need to be tightly screwed to clear metal floorboard for a strong body ground on the beam selector itself? I don’t think it does because I remember temporarily dangling it from my dashboard while I was still working on my carpeting so I’m thinking I may just have another bad beam selector. If that’s the case, could an open ground or improper vault, cause the beam selector to fail quickly and prematurely. I was also trying to figure out how to jump the wires in the harness behind the beam selector so that I could turn my headlamps on with a toggle switch that I wasn’t sure if that was possible because I couldn’t figure out the functionality of the beam selector if it is simply just to eliminate power to the high beam only, but the low beam runs constantly through it or separated from it or if the beam selector actually controls the low and high headlamps. One last question for the group, if I update my headlights to LED do I still use the same style high beam selector or does that get updated as well?
