AFR185 standard issue valve springs have .550 max lift capability.Does anybody have any recommendations for a "drop in" valve spring which uses the standard AFR retainers/keepers which will allow for a .580 lift solid flat tappet cam? I'm looking for a more economical replacement than the Comp beehive springs or drop in kits from Ed Curtis.
Per AFR, their upgrade springs require machining of the heads.
