What's the difference between Windsor and Cleveland engines?
The only commonality between the Boss 302 and the 351C/Boss 351 is the heads. That's it.On 2003-11-20 23:51, allenman85 wrote:
Actually the Boss302 was based on the Cleveland. It just was rushed out to meet the Trans-Am needs early.
True, but with the availablity of the Parker Funnelwebs and his port stuffers designed for that intake, a little extra work and $$$ changes that whole picture.The "Aussie" 2-v heads are suggested as an attempt to "civilize" the Clevelend heads for low rmp use on small block engines. Peak HP, will increase with 4-v heads, butlow/mid range intake velocity will be lower...usually causing a decrese in overall average HP under the useable rpm curve.
I agree with you to a point. With my 4v build it was PLENTY streetable. Mileage was not great, and it burnt 91 octane. BUT 4.11's made up for the lack of low end. With all else being equal a 2v will out perform a 4v when built to drive primarily on the street (ie gears, cam) It is not untill you begin the 4v the way it was supposed to be built that it will out perform the 2v imho. Both have their pros and cons...but both require two different builds--if you built up a 4v (big cam low gears single plane big headers), and switched ONLY the heads to 2v heads it would have performed better with the 4v heads. But on the contrary if you build a 2v motor (smaller cam dual plane intake, smaller headers, high gears), and switched ONLY the heads to 4v heads it would have performed better with the 2v heads.On 2003-11-21 10:45, indigo66 wrote:
I still don't buy into the whole "2V head is better for the street" theory. I know that the smaller ports have better velocity and what not, and that they are adequately sized for a mild 'small' block. However, I have NEVER seen a 2V clev run with anywhere near as strong as a 4V clev. I've driven both and in various states of build-up. Basically, if I had a 2 bl Clev, I would keep the heads probably. But there is no way in the world I would remove the 4V heads and swap on some aussie heads like a lot of people are doing these days. It'd be like taking AFR 185's off of a windsor to swap on a set of stock iron castings. Enough of that......
No, that doesn't fix anything. Oil control in a high RPM drag 351C is done with the lifter bores, specifically sleeving the right side to control bleed off. Managing clearances in the bearings and choosing the pump based on that, keeping the oil in the sump - thats where the work is done.To address the oil question: Clevelands have a minor oiling problem with mains #4 and #5, this problem becomes evident in severe duty situations (Ie: drag only cars) and can be fixed by installing an oil bypass from a point near the oil filter to a point located near the back of the block.
You've posted that link before and it is helpful. I used to run a Network54 Forum though, boy does that software suck in comparison to modern forum software. Wish the Cleveland fellows would migrate to a modern server/software package as it'd make the information contained there much more readily available.you might have then go here: Ford 335 "Cleveland" Series Engine Forum
