Yesterday, I was driving home on the freeway, and I heard something break from under the hood. Immediately, I experienced a loss of power, with the pedal all the way to the floor, and was getting very meager acceleration.
I was stopped at a light, and the car just stalled out. I was able to get it started again, and drove it home. So today, a friend and I pulled off the valve covers and found that the rocker shaft over cylinders 1-4 had snapped in two! Strangely, did a compression test, and found that the cylinders on the same side as the snapped rocker shaft were reading fine, minus cylinder 1, which wasn't firing. On the other side, three cylinders were not firing, but there doesn't appear to be any major issue there.
Could this be a sign that the car jumped timing?
