I’m using the following procedure:
Starting with #1 cylinder and going through the firing order. When the exhaust valve just starts to open, I put the intake to zero lash, tightened nut ½ turn, tighten set screw, then turn nut 1/8 turn. When intake fully opens and just starts to close, I put the exhaust to zero lash, tightened nut ½ turn, tighten set screw, then turn nut 1/8 turn.
After I set each valve then go back to #1 cylinder the rockers can be moved side-to-side by hand, but they are at zero lash. I assumed the rocker arms wouldn’t move. Is this normal and if not what I’m I doing wrong?
