My steering box leaks like crazy! I've never changed/rebuilt one before. Are they tough to remove or install? Is it worth a rebuild or buy a new one?
Point taken. Ill order a manual today. Some of my confusion comes from google searches that get me close to what I am looking for such as changing or repairing the steering for a 63 Galaxie or a 60's mustang, I found a lot of that. Ill get the book and see what I can figure out. Thanks!My suggestion, you have just purchased this car and have lots of questions, naturally.
Get the 1966 Ford and Mercury Shop manual, they have them on ebay very cheaply. I prefer the printed copy, but it comes on CD also.
1966 Ford Mercury Shop Service Manual | eBay
Find many great new & used options and get the best deals for 1966 Ford Mercury Shop Service Manual at the best online prices at eBay! Free shipping for many products!www.ebay.com
Read about steering boxes in Section 3, which talks about suspension and steering. You will need to apply if you have power steering or manual steering to the equation.
The procedure is spelled out- and some google searches of this forum have the info you are looking for. Most everything you are asking you can find the answers for here by some searches that you can do.
I only say this to help- showing you have done some basic research on the subject first is going to keep what I consider our higher level people here engaged in helping you. Asking too many questions without showing your digging into the process a bit more is going to not get you the types of people involved here you want.
And, to show that I am on your side here, I had a similar issue. Power steering box was leaking bad. Figure shaft seal, etc. Read about it in the afore shop manual, read about it here, it is a pain in the butt to take out.
But, I got lucky. The top cap 3 bolts were loose, I simply tightened them and 95% of my leak went away. I was so far in the weeds about thinking to remove the box, that I didn't do the basics first.
These might be dumb questions but I'll ask anyway. The mark you speak of on the steering shaft on my car is at approximately the 1 o'clock position with the wheels pointed straight ahead. The pitman arm has been replaced in the past and if I remember correctly it only went on one way (can't remember why). How would I know where the definite center position of the steering box is? Also, if the pitman arm only goes on only one way and the alignment is correct is there a reason the shaft needs to be repositioned to the 12 o'clock position?The steering shaft at the nut where the steering wheel bolts on should have a mark to show where center is.
It's basically just a chiseled mark in the top of the shaft.
That mark needs to be aligned with the steering box "center" of it's travel.
Steering boxes have a very definite "center" position.
It's sometimes called a "high spot" where it has increased torque to turn either direction past that high spot.
It's important to get it all centered.
With the steering shaft aligned with the box in the center position,
the pitman arm can then be installed in it's center position and the wheels should be "more or less" pointing straight ahead.
Final centering of the wheels is done by adjusting the tie rod ends while the steering shaft (and box) are held in their correct center position.
If you can't get it all centered, the car won't drive/steer properly.
