What brake fluid DOT 3 or 4
34K views 10 replies 7 participants last post by  Ggrahn
#1 ·
I am in the middle of changing all my brake lines on my 66 mustang due to the original proportioning valve leaking. Now with all new lines, cylinders, hoses, proportioning valve should I use DOT3 or should I go with the DOT 4. I have read that they are compatible.
Greg
#2 ·
If DOT 4 is easily available in your area go with it - it is slightly higher temp than DOT 3 But if DOT 3 is more available then use it.
Unless you drive pretty hard you won't notice the difference.
#6 ·
Quote]Stay away from Dot5 though. Its a racing fluid that needs to be changed before/after every race.[Quote
Bull$#!t, I have used DOT 5 in my 68 for over 5 years, as have many others.
Athough you are correct about its incompatability with DOT 3 & 4.
#9 ·
Whoa - easy! Time out! You're all 'right'. The difference is DOT 5 and DOT 5.1 - way different. However, if your easy choice is 3 or 4, then 4 as it's compatible, easy to find, and less hygroscopic (attracts less moisture). True, you won't feel any difference, but you'll have less corrosion over the long term.
#10 ·
This one time use brake fluid is making me giggle my ass off!
What the hell is that all about?
DO your brake LINES get hot when slowing down from a 200 MPH run once every two hours?
Or does the heat soak from a run or two of stopping make the fluid heat up and expand ad lock the caliper?
Whatever happens this sounds really stupid and I cannot fathom the reason. SO please one of you Racers school me in this retarded sounding brake fluid change after each race.
#11 ·
In the case of my cars, the drivers are hitting the gas and brake at the same time, ala left foot braking. The pedal will loose its stiffness noticeably after a weekend of racing. Keeping the pedal stiff is very important when racing a blind course in order to keep the drivers' confidence in the car up. Confidence = faster times; more podiums.
Besides, we get it for free. :D
