21 - 36 of 36 Posts
OK, I know this is an old thread, but I just ran accross it. I too was a little confused when installing the heads yesterday as to which, if any, of the head bolts went into water jackets. So I put sealer on every bolt. Does anyone see any problem with doing this? (other than a waste of time and material!)
waste of nothing but sealer. The sealer works precisely like the motor oil would have, but is also blocks water from getting into the passages on 5.0 blocks that have the lower head bolt holes threaded all the way into the water jacket like on a chevy small block. The 289's and other blocks didn't do this.
In ANY case, the oil lubricates the threads to ensure proper torque without binding, as does the thread sealer.
if thread sealer works the same as oil , then it could be used on rod and main bolts. next time try it on them and let me know how it worked
Don't go gettin' all huffy... It works the same. All my thread sealer is non hardening, and has the same lubricity if not better containing ptfe, as the oil on the threads.
But I never once said eluded to having used nor recommending to use them on bolts other than the head bolts.... So there! :cool: ;)
i didn' say you recommend sealer for other bolts . not all thread sealer is the same , better to spec the ones to use .
21 - 36 of 36 Posts
