Where to set Rev limiter.
15K views 17 replies 11 participants last post by  asr427
#1 ·
Hi Guys,
Well the 302's all finished and its ready for the engine dyno. Before I go and blow it apart can anyone give me a good idea as where to set the rev limiter.
Ive got a stock replacement crank (CAT), Eagle SIR I Beam rods and KB115 pistons and FMS billet flywheel. (All balanced)
Edelbrock RPM cam, heads, intake and carb with Crane roller rockers, comp cam lifters, rods and timing gear.
I was thinking around 5,500 rpm, is this too high or a bit to low? This is to set where the limiter cuts in as the engine is going in front of a manual mission.
Ive had a hunt on the forum but cant see anyone running a similar setup with an answer.
Many thanks
#3 ·
I agree. With RPM heads, cam and intake it will like way more than 5500rpm. With a complete arftermarket rotating assembly you've got no worries. 6500rpm easy.
#4 ·
Yeah, I'd say set it at 6500. Set the rev limiter where it will be a safety net, not something you're going to bump into every time you're about ready to shift. That bottom end should be good for 6500 no prob.
#6 ·
Many thanks, that's great. Ill go for that then.
Pic of finished motor attached.
Cheers
#7 ·
Great looking MOTOR...!!!
Maybe that is a fancy kind of distrubutor I have not seen before, but I have never seen plug wires that are all in a row like the way your plugs are wired.....
Did you do that just for the sake of the photo...?
#9 ·
^^^ What he said, 500 rpm above peak power.
#12 ·
I'd go 1000rpm above peak power... or at least where the power starts to fall off quite a bit. My 289 makes peak power at about 6200rpm, but drops less than 10hp at 7000rpm. If I shift at 7000, I pretty much have constant power to the wheels before and after the shift. If I shifted at 6700, I'd be down on power for the first couple hundred RPM in the next gear.
#13 ·
Something else you may have to consider is the accuracy of the setting on the rev limiter...at least I did.
I bought a pertronix rev limiter (can't remember the name of it right now). I want it to kick in around 6800 or so. I had to set it at 7300. Setting it to 6800 caused the limiter to kick in at something like 6300 or 6400. I even checked my tach with another one...they were within 100 or so of each other.
Yes...I have the limiter set to 6...I mean 8 cylinders.
My peak power is in the 6400 - 6500 range so I could probably set the limiter to 7000+ if I dare, but according to a simulation I ran with EA Pro, my intake valve will begin to float at about 7200. I figure 6800 is high enough.
#14 ·
Thanks for the comments guys, Ive certainly got what I needed and that was a safe figure. Ill see how it pans out on the dyno I just wanted to make sure I wouldnt kill it 1st run out!
this motors for a Cobra rep so I think Ill probably scare myself before I hit max bhp on the road!
The eagle eyed amongst you are correct, when I first wired up the plug leads I followed the wrong picture in Tom Monroes book, this is for one of those electronic distributors, Now Ive wired them up with right firing order it dont look so pretty! Luckily I only had to move four leads.
#16 ·
Hi Frdnut,
Yes its a March bracket and pulley set with additional waterpump nose cover and alternator fan. The bracket is 30025, pulley set 1675, nose cone 312 and fan 221. The march supplied hardware was a bit naff so I sourced my own locally and from the US as you cant buy long bolts in imperial sizes in the UK (well not in cap head anyway) So all in all it was a bit of a fiddle getting it to fit what with cutting the spacers down to suit the Flowkooler pump Ive fitted but Im happy with it.
Cheers
Andy
#18 ·
Will do, Ive heard similar comments about Edel's claims. Will be interesting to see what I get.
Cheers
